I am finding very difficult and confusing to understand the concept of The Open Dain or Open collector configuration.
Can someone explain in clear and simple English with an example.
TTL logic ... The output can only be pulled low. Some external circuit is assumed that will pull the output high. This allows for outputs to be tied to non-logic levels......., higher voltages or higher currents. It also allows more than one output to be tied together.I am finding very difficult and confusing to understand the concept of The Open Dain or Open collector configuration.
Mod edit: shown images full sizeTTL logic ... The output can only be pulled low. Some external circuit is assumed that will pull the output high. This allows for outputs to be tied to non-logic levels......., higher voltages or higher currents. It also allows more than one output to be tied together.
CMOS Logic ... the open drain can be either the low side (N-MOS, active sink only) or an open drain on the high side (P-MOS, active source only). Advantages are the same as TTL.
Would pictures help?
Thread starter | Similar threads | Forum | Replies | Date |
M | Open drain | Microcontrollers | 17 | |
I | Help with Open Drain output (pull-up resistor?) | General Electronics Chat | 12 | |
ISOLATED Open Drain Power stage for PLC Design | Power Electronics | 6 | ||
W | Drive a LED with open-drain output | General Electronics Chat | 8 | |
N | Open drain output LED control | Analog & Mixed-Signal Design | 9 |
