Open door alarm
Discussion in 'General Electronics Chat' started by Glpcv, Apr 19, 2014.
  1. Glpcv
    Sep 14, 2013
    Have 2 freezers and 1 fridge all uprights in garage. Have a little strobe light i found in my junk box. Want to put switch (micro,proximity...etc) on each door to signal when open. Would i connect all in parallel and go to a relay then on to strobe ? Just bare bones off/on no timers .....
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    Yes, that would probably be the easiest way. Are you okay with the strobe flashing every time you open any one of the doors?
  3. Glpcv
    Sep 14, 2013
    Yes that wont be a problem. Strobe will be mounted on wall above the units, only time flash will be visible would be when i'm re-entering the house...99% of the time it's ME leaving one open....
