I wish to interface the output of one Device(A) with another Device(B) that requires a metallic contact closure to start Device B. Device A has two outputs:
1. open collector
2. common held at 0v
The supply voltage is of device A is +5v and 0v
I do not know anymore technical info about device A
Device A is operational when a push button code is input by keypad. At this point the open collector should change state. Can anyone suggest a test procedure to determine whether the open collector is working properly.
Once I know Device A is working I need to feed this output into an interface circuit input that will cause a relay to operate and provide a contact closure to turn on Device B.
I have put together an interface circuit using an NPN transistor (BC547C), a relay - Maplins 2A DPDT 5vdc (coil resistance 125 ohms/operate current 40mA), a diode (IN4007S) and a base input resistance of 6 Kohms.
The transistor collector is connected to one side of the coil and +5v to the other side of the coil. The emitter is connected to 0v and the diode is connected across the coil to protect the transistor against switch off transient voltages.
I have connected the base via the 6Kohm resister to the open collector output. I have connected the common to my 0v of the interface circuit. However, Device A's open collector output does not operate the relay in the interface circuit when I key in the correct code into Device A.
I have tested the interface circuitry in stand alone mode and when a resistive (6kohms) +5v is applied to the transistor (BC547C) base the relay operates with the contacts closing accordingly.
So, I would be grateful for any advice regarding testing the Device A's open collector circuit to prove it works. I would also appreciate any suggested adjustments that may be needed to my interface circuit to enable it to work with this open collector output.
Terence Sutton (tigerterry)
1. open collector
