The concept you are describing sounds like nonsense. You don't "split" logic signals, but you can drive multiple loads. The pullup for an open collector (open drain) has an upper limit and a lower limit. Check out the following article.I want to split the signal coming out of an open collector transistor output.
My understanding is that the sensor will pull down to 1.0V with a 10K Ohm pull up resistor
As simple as putting a 5K Ohm pull up resistance ?
Thoughts ?
We're not mind readers!I want to send identical signal to two locations (tow displays)
An open collector output probably isn't microwave.The concept of "splitting" does occur in microwave electronics with circuits like the Wilkinson Power Divider.
http://en.wikipedia.org/wiki/Wilkinson_power_divider
It is much simpler with logic signals.
Wondered why I'd never heard of it.his typo - two displays
Of course not. I was trying to cite an example where splitting was a relevant concept.An open collector output probably isn't microwave.
The TS mentioned "tow display" - google didn't find anything relevant looking.
The TS was so vague, you have to get right down to eliminating things it isn't.Of course not. I was trying to cite an example where splitting was a relevant concept.
