I am looking for a simple bargraph circuit that will indicate how long a button is pressed. Full bargraph when button is held for 2 seconds. (adjustable down to 1 second) The leds will ramp up and down during the time the switch is closed and open.
The circuit should run from 12volts.
As simple as possible. I assume a 555 timer with a LM3914 ic will be needed.
The switch will be a standard TLP621 optoisolator connected to a computer.
This circuit will be used to indicate when corrections are sent to my telescope mount when it is tracking stars.
Thanks for any info you can provide.
Dwight
Dwight
