Opamps Negative feedback Voltage Divider doubt or typo?
Discussion in 'Analog & Mixed-Signal Design' started by quique123, Jul 6, 2016.
Thread Status:
Not open for further replies.
  1. quique123
    May 15, 2015
    34
    In this part of Ch8
    "If R1 and R2 are both equal and Vin is 6 volts, the op-amp will output whatever voltage is needed to drop 6 volts across R1"
    Shouldn't that read "...op-amp will output whatever voltage is needed to drop 6 volts across R2"?
  2. AlbertHall
    Jun 4, 2014
    2,278
    450
    The first statement is true. The second is only true if R1 = R2.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,384
    653
    The correct way to look at it is: 6V at the non-inverting input causes R1 to have a current of 6mA. Since, in an ideal opamp, no current enters the inverting terminal; the output voltage will be
     \small 6V+I_{R1}*R2
  4. quique123
    May 15, 2015
    34
    dl324
    Thanks. You seem to understand my confusion :) The reason that sounded weird to me is because it sounded like the Vout was making go through R1 from right to left.
  5. crutschow
    Mar 14, 2008
    13,509
    3,385
    That's exactly what's happening.
    Vout is the controlled voltage which is forced to go to 12V by the op amp so that the voltage at the (-) op amp input is 6V to match the 6V at the (+) input.
    (The diagram left-to-right arrows show electron flow from negative to positive. Conventional current flow would be right to left. Is that what you find confusing?)
  6. dannyf
    Sep 13, 2015
    2,196
    417
    That happens to be true here, only because R1 is the same as R2
    The statement given in the book is true universally regardless of R1 or R2s values.
  7. quique123
    May 15, 2015
    34
    I've visited a few sites in YouTube, electronics-tutorials.ws where they always use conventional current flow.
  8. crutschow
    Mar 14, 2008
    13,509
    3,385
    Yes. I always use conventional current flow (which I find easier to understand), as do many references, but whoever did your reference tutorial was familiar with electron flow (I think it's used in all military electronics courses, for example) and thus wrote it with electron flow designations.
    I think the useage of electron flow comes from the days when electron tubes (valves) were the only active electronic component, and you need to use electron flow to explain tube operation.
  9. EM Fields
    Member
    Jun 8, 2016
    253
    44
    If we start at the very beginning, do you understand why an opamp is considered to have infinite gain ?
  10. #12
    Nov 30, 2010
    16,705
    7,355
    Do you understand that "electron flow" and "conventional flow" are models which people use to predict behavior? Do you understand that it doesn't matter which model you use, as long as you use it consistently? Both models work. You can use the one that is most convenient to you. What you can not do is insist that everybody does it your way.
  11. quique123
    May 15, 2015
    34
    EMFields
    Well no, I don't know why other than they are modelled to have infinite gain in the ideal model.
  12. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Infinite gain is required in an ideal opamp so that the output will be exactly 0V, if and only if, the differential input voltage is identically 0V. AFAIK a yoctovolt is the smallest unit of voltage with a named prefix. It is 1 x 10^-24 volts. In a ideal opamp, a differential input of 1 yoctovolt would send the output to the rail. In a typical opamp a differential input of 1 yoctovolt and a voltage gain of 120 dB, the output would be 1 attovolt (1 x 10^-18). Can you now see the difference?
  13. JohnInTX
    Jun 26, 2012
    2,394
    1,051
Thread Status:
