OpAmp
Discussion in 'General Electronics Chat' started by mashee, Feb 17, 2010.
  1. mashee
    Feb 17, 2010
    What could cause a OpAmp to fail for high supply current...How can one test this part in a lab setting..
    Datasheet says In+ to 2.75 V, VDD to 5V,Vss to GND,shdn to 5.5v ,out to 2.75v , IN- to loop (what does this loop mean)
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Something seriously wrong with tying the OUTPUT of the OpAmp to a 2.75V supply. I would tie IN+ to 2.75V, tie IN- to OUT with a jumper, and then read the supply current.
  3. mashee
    Feb 17, 2010
    Thanks Mike
    That was super quick....I will try that out...
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The "loop" is when the output of the opamp is connected to its (in-) input so the opamp is a follower of the +2.75V in+ input voltage which makes its output also +2.75V.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Post a link to the datasheet so we don't have to guess what all that stuff means.
