opamp
TAKYMOUNIR
Joined Jun 23, 2008
352
opamp.JPGin fig 1 we see that there are 2 diodes between the 2 input ,and these for protect the input of OPAMP so it will never the difference between 2 input be more than .7v ,my question is why we connect no inverting input to 10k to ground and not connected direct to ground?
and also in the second OPAMP we connect the 2 diodes after 47k? so why this
and in fig 2 we connect 200k parallel with .01uf ,so is this low pass filter and how can I chose the value of 200k and .01uf
Sensacell
Joined Jun 19, 2012
3,453
It would be helpful if you would provide more information about what you are building? it's not at all clear from the schematic.
Alec_t
Joined Sep 17, 2013
14,335
If the inverting and non-inverting inputs of the opamp have similar resistance paths for DC bias current the effect of DC offset drift will be reduced.
