The Electrician
- Joined Oct 9, 2007
- 2,970
Back around March 2006 on the Usenet newsgroup sci.electronics.design, somebody asked about the original Howland source, and Walter Jung replied:
http://www.datasheetarchive.com/dl/Datasheets-23/DSA-457096.pdf
Also, another poster mentioned that Apex Microelectronics had an application note AN13 with some discussion of the Howland source:
http://www.cirrus.com/en/support/library/T15.html
I tracked down a source for the old Motorola AN587 here:On current and earlier literature references to Howland
Current Source/Pump circuits:
1) There is an excellent discussion on pages 189 - 195 of Tom
Frederiksen's op amp book, Intuitive IC Op Amps (National
Semiconductor, 1984). Frederiksen analyzes both the 4 and 5-resistor
forms of the circuit. This is very good stuff, indeed. In his
bibliography, he mentions the GAP/R apps manual from 1966. Although
Frederiksen doesnt specifically mention it, Bob Pease encouraged and
influenced what did appear within his fine narrative. (RAP > WGJ
email, March 2006). Pease calls Frederiksens book a little classic
in its own right, a point with which Id agree. He also contributed a
Foreword to the book.
2) From my own IC Op Amp Cookbook 3d Ed. Ch. 4 References, pages
218 223, there are at least a couple of key references to Howland
type circuits.
a. The first is Tim Henrys "Analysis and Design of the Op Amp
Current Source", Application Note AN-587, October 1973, Motorola
Semiconductor Products, Inc., Phoenix, AZ. Note: archival copies of
older Motorola Semiconductor app notes are available from Freescale
Semiconductor. To download the Henry app note go to:
http://merchant.hibbertco.com/fs10/pdf-docs/freescale/an587.rev0.pdf
b. There is also the 1965 GAP/R applications manual, now
available online as per the URL indicated by Dan Sheingold, below.
c. Dan Sheingold's GAP/R Lightning Empiricist article from the
January 1964 issue sheds light on the Howland circuit, and actually,
is the first public mention of it. This article is available online
at:
http://www.philbrickarchive.org/1964-1_v12_no1_the_lightning_empiricist.htm
3) Dan Sheingold summarized the history of the Howland circuit
from his days at GAP/R (DHS > WGJ email, Feb. 2006) as follows:
Walt:
The "Howland circuit" was originally described in a personal note (ca
1961(?)) from Brad Howland (then at MIT)
to George Philbrick, who gave it that name.
A form of the circuit can be found in print in the Philbrick
"Applications Manual..." (page 66, module III.6)
http://www.analog.com/library/analogDialogue/archives/philbrick/064-068.pdf
Adaptations of it appear in modules III.7 and III.9.
Bob Pease has done some further development on the circuit,
with improvements to stability, range, etc.
Best regards,
Dan
There have been folks looking for the original Howland paper, even
posting lists here of Bradford Howland references, and speculating on
which one had the discussion re the circuit. Hopefully the above will
put this to rest. The first public appearances were within GAP/R
literature items, in 1964 and 1965, as above.
Walt Jung
