Hi all,
I would appreciate your help with a project I am having. I want to implement a supplier that will take a signal form a signal generator amplify it and send it to a step up transformer. The more I try to understand the more complex it gets and here is why I need your help!
So in simulations there arent any difficulties just to take the signal with an opamp (x10 amplification) and then send it to a 1:50 step up transformer. The signal is a 5Vpp sinusoidal. But from simulations to practice there are always complications.
Could you highlight to me the main spots that I should take care. Also I cannot find any HV transformer to order. All I find online is for mains voltage input to some more volts 240/480 lets say. My current model gives an almost 3kV voltage output.
Also, what about impedance matching in the primary and secondary? Where should I get started with?
I will appreciate anyone's help and I am very willing to first understand in depth before I go to implement it so bare with me and hopefully with your help I ll get there.
Thank you
Thank you
