Hi, I constructed a circuit similar to that in Forrest Mims' thermistor opamp trigger on page 37 of science and communications circuits (vol 2) in case someone has it lying around. basically it's non-inverting comparator with a 100k pot between +in and ground and a 10k thermistor between V+ and -in in a voltage divider with a 10k resistor to ground.
I'm getting quite a bit of output current when i would think it should be off. Anyone have any insight? The output current is like 1/2-2/3 when it's 'off'. I can post a picture if that helps.
I wanted to use this to switch a MOSFET to turn a fan on in an external hard drive enclosure when the temperature passes a certain point.
