Opamp resistor values
Discussion in 'General Electronics Chat' started by nepdeep, Nov 7, 2012.
  1. nepdeep
    Sep 14, 2011
    139
    Why can we not put 1 ohm or 1 Meg ohm? in the input terminal of the opamps....Does it have something to do with the bias current?
  2. crutschow
    Mar 14, 2008
    13,508
    3,384
    Do you understand Ohm's law? Too small a resistor and the current becomes too high for a given signal voltage. Too large a resistor will cause a voltage drop (offset) due to the op amp bias current. Thus typical op amp resistor values go from a few kΩ to perhaps a few hundred kΩ. But if you have a very low bias current input op amp such as a MOSFET or JFET type than you can go above a megohm if needed
    nepdeep likes this.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Opamps do not have "terminals". Train and bus stations have terminals.
    Opamps have inputs and outputs. What are you talking about?
    Are you talking about an inverting or a non-inverting opamp amplifier?
  4. nepdeep
    Sep 14, 2011
    139
    ya and mr cru..explained
  5. ScottWang
    Aug 23, 2012
    4,933
    777
    Talk about what you want to do?
    Talk about why you want to use 1MΩ in the input pins of Op Amp?
