opamp problem
Discussion in 'Homework Help' started by Adsa, Oct 22, 2012.
  1. Adsa
    Mar 10, 2012
    8
    I was performing some experiments to get used to opamps. I constructed separately a log and an antilog circuits.I then connected them simultaneously but the output was not equivalent to the input as i expected. Why is this? how can I resolve it ?
    i tried adding another opamp in between as a buffer, but that still did not work.
    http://i1261.photobucket.com/albums/ii583/Adam_Sant/aaaa.jpg
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Simply because the log and antilog circuits are modelled after the diode equation which uses the diode's reverse bias saturation current. This is different from one diode to the next.
    Hence your antilog circuit is not an exact inverse of your log circuit.
    Adsa likes this.
  3. Adsa
    Mar 10, 2012
    8
    ow ok thanks. i derived the equations using the tracking property and now i understand better. So is there any alteration i can make to make the circuit to give me vin=vout? thanks :)
