OPAMP Output Clipped
Discussion in 'General Electronics Chat' started by Engineer_tech, Jan 26, 2015.
  1. Engineer_tech
    Sep 19, 2014
    31
    Hello to All,
    I have an OPamp setup in a non inverting configuration for the amplification of a very small signal.The Amp has a gain of 70.
    the output of op-amp is 200mV p-p sine wave signal but is clipped from one side.I am not sure what could be the reason and how can i fix to the proper sine wave.
    here is a bit of description to give you an idea.
    I am using OPa 211 op-amp in non inverting configuration with feedback resistor value of 70k. The input of an opamp is a small signal(i cannot scope it as its less than few mv) coming from a coil induced by another coil.
    P.S i have made the circuit on Bread Board for testing and i didn't connect any capacitor yet to filter the output
    Please share your quick suggestions
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    Without looking I am guessing that one of your inputs or outputs is too close to one of the power rails. Take a look at the common mode input range in the data sheet.
    absf likes this.
  3. #12
    Nov 30, 2010
    16,705
    7,358
    Without looking, I am guessing you didn't even use 2 power supplies, you have no resistor from the inverting input to common, your common point isn't centered, etc.
    This is why posting a schematic is a requirement for this kind of question.
    absf likes this.
  4. Engineer_tech
    Sep 19, 2014
    31
    well i am using two power supplies -Vee and +Vcc .
    here is the attached picture of the input vs output
  5. #12
    Nov 30, 2010
    16,705
    7,358
    You don't get it. We need a schematic to tell what went wrong.
    Lundwall_Paul likes this.
  6. Engineer_tech
    Sep 19, 2014
    31
    oh i am sorry i thought i attached the schematic too.i mean the circuit is just an opamp in non inverting configuration.
  7. #12
    Nov 30, 2010
    16,705
    7,358
    Unknown power voltages, unknown resistance to ground, unknown input circuit...
    I give up.
  8. Engineer_tech
    Sep 19, 2014
    31
    i apologize for not providing enough information on the schematics circuit
    here is the description:
    Vee=-5v
    Vcc=5V
    feedback resistor: 70K
    resistor to ground :1K
    I am sorry i am a newbie a still trying to pose my question in a way other can understand.
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    With a feedback resistor of 70 K and a resistor of 1 K to ground the gain is (70 K + 1 K) / 1 K = 71 times.
    71 times the 200 mV = 14.2 Volts, what not can happen as your total voltage on the opamp is 10 Volts.
    Bertus
    PS what opamp are you using.
    Many opamps will not work rail to rail.
  10. Engineer_tech
    Sep 19, 2014
    31
    I am using 0pa 211 from TI.actually the output voltage os 200mv. The input source is an output voltage of a coil been driven by function generator.After using Amp with a gain of 70 i get an output signal of 400mV
  11. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Can you make a drawing how the function generator, coil and opamp-circuit are connected?
    Bertus
  12. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    You don't show what you did with the SHUTDOWN pin8. The datasheet pp15 says it has to be connected and not left floating.
    Not sure about the vertical deflection settings in your picture of the scope. I see an input of 2Vp-p on CH2 not 200mv. CH1 says 200mv and it knows its a 10x probe (according to the readout) but if it were off a factor of 10, you'd be close to clipping at the rails. AC coupling would account for the baseline shift. Sometimes, my scope gets confused in that way - just thinkin'.
    Thinkin' more, with AC coupling, the output signal could be railed already and you are just seeing some ripple on the output.
  13. Engineer_tech
    Sep 19, 2014
    31
    I am sorry i wont have the drawing of the coil and how its connected inside, but i was given a fork kind of thing which has to be driven from one side with fucntion generator the fork vibrates and induce voltage and the other side of the coil .I have no clue of this concept and how it works
    The output of the other coil is small and i need to amplify it in order to scope it.
    so that what i did i connected the output lines of the fork to the input of amp and tried to amplify it all i got was a few hundred mili volts signal with clipped ends i need to remove the clipped ends of the sine wave.
  14. Engineer_tech
    Sep 19, 2014
    31
    well i am using the s0-8 package and on datasheet Page 3 (first IC) says it has to be NC that is why i left it floating.
    JohnInTX likes this.
  15. atferrari
    Jan 6, 2004
    2,673
    785
    Next time, like this, please.
  16. Engineer_tech
    Sep 19, 2014
    31
    Thank You for All the nice people out here.
