Opamp oscillator
Discussion in 'Homework Help' started by xxxyyyba, Nov 22, 2015.
  1. xxxyyyba
    Aug 7, 2012
    249
    Here is my task and solution for a)
    Any suggestion for task b) ?
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    What your thought about this ? Also do you recognize the building blocks?
  3. xxxyyyba
    Aug 7, 2012
    249
    When v12(t) reaches in amplitude value of VD+VZ=6.8V, DZ1 will start conducting in forward direction DZ2 will start conducting in reverse direction. While conducting, they will provide constant voltage drop on R, 6.8V.
    That's what I know :)
  4. crutschow
    Mar 14, 2008
    13,505
    3,378
    The two top circuits are called All-Pass filters, as their ouput phase changes with frequency but the amplitude is constant.
    xxxyyyba likes this.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    At first glance the answer looks obvious. But to by honest the more I think about it, the more confused I get. So I don't know how you can find this output voltage.
  6. xxxyyyba
    Aug 7, 2012
    249
    Ok.
    This is very strange example I would say :) Even simulation in Multisim show result which I would not expect.
    Thanks anyway.
  7. JoeJester
    Apr 26, 2005
    3,402
    1,227
    I got the attached results in a simulation. There was NO VD in your diagram. I did set an initial charge on the capacitors to kickstart the oscillations. Post your multisim.
  8. xxxyyyba
    Aug 7, 2012
    249
    R5 in your schematic should be 10k
    I will post multisim
  9. JoeJester
    Apr 26, 2005
    3,402
    1,227
    I followed your R2 < R3 instruction in b)
    I will change it back to 10 k and rerun the simulation and post the results
    on edit ... added two images ....
