HI
i have an opamp (opa211) setted up in non inverting configuration with R2(feedback) resistor value as 100k and R1 as 1K. I need a gain of around 100.
Applying a signal to the input of the Amp i am not able to get an amplified signal at the output.The output i am getting is little bit amplified version of the input.Apparently i have rechecked the connections, i don't see any loose wire or bad connection.i am not sure what the problem could be.
I have attached the pin configuration Diagram for OPa211.
Here is the details of the input i Applied to the Amp.
V+=10V
V-=-10V
In+=sine wave 500mV p-p
In- =grounded
please comment
V+=10V
V-=-10V
In- =grounded
please comment
