the answer is highly likely a "no", but check the datasheet for sure.Actually I wanted to know if we can give 20V input to the opamp with 3.3V supply...
The LMV321's input maximum limits are the voltage rails, in your case ground to 3.3v.Actually I wanted to know if we can give 20V input to the opamp with 3.3V supply...
If you want open-loop gain, look at comparators instead of opamps.<snip> open loop Opamp?
by Duane Benson
by Jake Hertz
by Robert Keim
by Duane Benson
