opamp design
Discussion in 'General Electronics Chat' started by CHIDANND, Nov 25, 2015.
  1. CHIDANND
    Nov 25, 2015
    Hi sir,
    Actually i need the clarification that
    1)Is it possible to design a opam which gives output of 2.5v w/o any input
    2)with input 5V it should provide the output as 2.75V
    Hoping for your favorable response..
    Thanking you sir,
    Regards:
    Chidanand M
    (email address removed by moderator)
  2. DickCappels
    Aug 21, 2008
    2,749
    665
    Is what you are asking for a circuit using a opamp? If so, the answer is "yes".
  3. Bordodynov
    May 20, 2015
    669
    194
    See
    DickCappels and ErnieM like this.
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    Do you want the output to go from 2.5V to 2.75V as the input goes from 0V (or floating) to 5V?
    Or does @Bordodynov 's solution get at the problem?
    If so, the required gain is (2.75-2.5)/(5-0) = 0.05
    the required offset is (2.5-0) = 2.5V?
    This can be done with just a power supply and a resistive network; no opamp required.
