I have a very general question about using an OpAmp as a current source. For example, In the attached schematic I would like to supply a fixed 2mA through the 2 load resistors (the 4.4k will ultimately be slightly variable). If I use a 1V reference voltage, my series current through the resistors should be 2mA (1V/500 Ohm). However, I am only seeing 1 mA flowing through the resistor, and a voltage of 0.5 V at the V- terminal (across the 400 Ohm resistor). This device has a very low input bias current of 20 pA, so Vp should equal Vn = 1V. Could someone explain what I may be missing about this and/or what limitations the opamp choice has for this type of design?
