OPAMP- Can we replace opamp with any other electronic component
Discussion in 'The Projects Forum' started by md yasir, Nov 2, 2015.
  1. md yasir
    Sep 14, 2015
    16
    can we replace opamp with any other electronic component
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    An opamp is a large conjuction of componenents.
    They can not be replaced with a single electronic component, but an other opamp.
    Ever had a look at the internal schematic of an opamp?
    This is the internal schematic of the old LM741.
    Bertus
  3. DickCappels
    Aug 21, 2008
    2,768
    669
    What do you mean by the term "replace"? Does your question ask whether a circuit that would normally use an opamp could be designed without and opamp, or does your question ask whether another component(s) can be placed in an existing circuit in place of an opamp?
    A few years ago I replaced a broken high speed opamp with a discreet transistor-only amplifier because I didn't have the patience to wait for a replacement high speed opamp to me sent to me.
    md yasir likes this.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,687
    1,297
    As a lab project while in school, I designed and built a complete home stereo amplifier channel with nothing but CMOS 4069 unbuffered inverters. Phono cartridge input, RIAA equalization, treble and bass tone controls, and a BTL class D output stage. Limited bandwidth, unimpressive distortion, and not much speaker power, but it did work.
    ak
  5. #12
    Nov 30, 2010
    16,676
    7,321
    As AK demonstrated, there are ways around using an op-amp, but there is no such thing as one component that can replace an op-amp. I can imagine using a single bjt base and emitter as a differential input, but the output...how can one, single, collector do all the things an op-amp does?
  6. OBW0549
    Mar 2, 2015
    1,392
    936
    No.
    #12 likes this.
  7. md yasir
    Sep 14, 2015
    16
    thanks
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    about thirty transistors and resistors...
