Opamp buffers and gain
Discussion in 'General Electronics Chat' started by IvarsOzolsDB, Jan 13, 2014.
  1. IvarsOzolsDB
    Aug 24, 2012
    27
    5
    Newbie question. :) Is there any difference between opamp in unity gain configuration (buffer) and opamp in non-inverting configuration with gain of 2? Is there output impedance difference etc?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Many opamps are not stable in a unity gain/voltage follower configuration; you need to read the datasheet (s) for the opamp(s) in question - so no; they are not the same.
  3. crutschow
    Mar 14, 2008
    13,472
    3,361
    The gain of 2 circuit bandwidth will be 1/2 the unity gain configuration (equal to 1/2 the GBWP of the op amp). There may also be some peaking in the frequency response from stray capacitance at the inverting input node.
    The closed-loop output impedance will be higher than in the unity gain configuration, but will still be very low.
    Any op amp input offset will be multiplied by a factor of 2.
    I believe those are the primary differences.
    Edit: The above assumes the op amp is stable in those configurations, as SW noted.
  4. Veracohr
    Jan 3, 2011
    559
    77
    Yes, the input impedance is increased by a factor of the closed loop gain
    Rin = Rin*Acl
    And output impedance is decreased by the same factor:
    Rout = Rout/Acl
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    Might be worth double checking that.....
  6. Veracohr
    Jan 3, 2011
    559
    77
  7. crutschow
    Mar 14, 2008
    13,472
    3,361
    The input impedance of a typical op amp is already so large that any increase due to the closed loop gain in a non-inverting amp configuration is generally of little practical significance.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Hi Veracohr,
    What does Acl mean in your earlier post?
  9. shteii01
    Feb 19, 2010
    3,500
    511
    I assume Close Loop Gain.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Most likely. The issue is with the input / output resistance relationships with respect to that closed loop gain - as quoted by Veracohr in post #4.
  11. Veracohr
    Jan 3, 2011
    559
    77
    Yes that's what I meant.
    I see now. Not the closed loop gain, but the loop gain (1+Aβ), where A is the op amp's open loop gain and β is the feedback network factor R1/(R1+R2). Correct? Sorry for giving out misinformation.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    No need to apologize. Simple mistake. BTW the loop gain is usually taken to be Aβ. Some people include a negative sign which probably pre-supposes negative feedback is being applied.
  13. LvW
    Jun 13, 2013
    674
    100
    Perhaps not too important in the context of this thread - nevertheless I like to mention that the loop gain is the gain of the COMPLETE loop, that means: including any sign inversion within the loop. Remember that there are circuits with another active inverting element within the loop - and in this case, the loop is closed using the non-invering input node of the main amplifier.
    Thus, the loop gain usually should be taken to be (-Aβ).
    I think, this consideration is important because very often this is the background of some misunderstandings in finding stability margins:
    Is it necessary to investigate the loop gain at a the frequency with -180deg or with -360deg phase shift ?
  14. IvarsOzolsDB
    Aug 24, 2012
    27
    5
    Thanks guys for answers. The pratical appliacion for the question was about buffer before Linkwitz-Riley 24db/oct filter stages. Do I need add an extra unity gain buffer before subsonic filter stage or do balanced input stage will manage right output impedance etc? Schematic attached.
  15. Veracohr
    Jan 3, 2011
    559
    77
    That stage is fed by an op amp, I don't see why a buffer would be necessary. The op amp has sufficiently low output impedance.
    IvarsOzolsDB likes this.
