At this point, we're waiting to hear from our OP to see if they are getting an appropriate signal out from the comparator. Not much progress can be made until that happens.Then do you think these transistor drivers will work? If zeners are too slow you could always gang however small signal diodes in series to drop the required voltage. Not an elegant solution, but it'll work. It will be rail to rail with this driver unless I'm mistaken.
This cannot be the case as TL082 "Output short circuit duration = Continuous" as specified in the datasheet.I think your LT082(TL082) is burned because you don't have a resistor between its output and the BJT's base. Check the maximum power dissipation of the chip.
The opamp has been replaced by a comparator, which will have a tremendous improvement in the slew rate.Also, the slew rate is decreased due to the low impedance seen by the op amp's output.
No.So if i use a resistor between comparator's output and bjt base - will it work??
Are you getting any output from the comparator?could u draw comparator with voltage follower?...i dont wanna make it wrong..
You have connected something incorrectly. It should not be getting hot at all.no i cant get pwm signal from output of comparator...there are sinus and triangle signal on comparator opamp's legs but no pwm output? i guess it cant compare them.. and the comparator opamp is getting heat...
