Opamp amplifier
circuit4pcb
Joined Feb 4, 2013
20
Hello Gents,
I really need your help on this. I have an accelerometer whose output varies from .41V to 4.59V and I need to use an amplifier (opamp) to achieve 0-2.5V, but I am not getting favorable results. I will be using op184 and also have a 2.5V stable voltage reference in case i need it. Can someone please please help? I have been using multisim and have used inverting and noninverting amplifiers with various gains but i just cannot get results
#12
Joined Nov 30, 2010
18,224
Use a resistor voltage divider to multiply by .598
That gets you in a range of .2452 volts to 2.7452 volts
Then use a DC offset of .2452 volts
The result is 0 to 2.500015 volts
The numbers come out so perfect that this looks like a homework problem.
ErnieM
Joined Apr 24, 2011
8,377
I would look hard at just using a 2:1 divider. Here's why:
Your end points become .205 to 2.295, or 2.04 in a 2.5 V span, or 81% providing useful data.
If your signal drops below .2V or above 2.3V you have an indication of problems.
Finally, it is simpler, cheaper, and more stable then an op amp circuit.
rahdirs
Joined May 22, 2013
28
why not use a comparator along with a rail to rail op-amp.
So that whenever vin < 2.5 V,Vout = 0;otherwise Vout =2.5V.
He never mentioned about the kind of output,only that it should be 0-2.5
Ron H
Joined Apr 14, 2005
7,063
I don't think he is looking for greater-than/less-than. I think he wants to send the op amp output to an ADC.
circuit4pcb
Joined Feb 4, 2013
20
Ron,
Overall, you have hit the issue on the nail. This is exactly what I needed for an ADC input. Maybe u can help me understand the logic of it all as well. I really want to know how uou derived this since I also have an LM35d question where i want to measure -40 to 175c and change to 0-2.5v out.
Ron H
Joined Apr 14, 2005
7,063
Ron,
Your desired output is related to the input as follows:
\(Vout=Vin(\frac{2.5}{4.59-0.41})-0.24522\)
My op amp circuit output as a function of its inputs is as follows:
\(Vout=V1(\frac{R3+R4}{R3})(\frac{R2}{R1+R2})-V2(\frac{R4}{R3})\)
Let V1=Vin, and V2=2.5
Now,
\(Vout=Vin(\frac{R3+R4}{R3})(\frac{R2}{R1+R2})-2.5(\frac{R4}{R3})\)
We can see by inspection that
\(2.5(\frac{R4}{R3})=0.24522\)
Therefore,
\(R4=.098086(R3)\)
Substituting,
\(Vout=Vin(1.09896)(\frac{R2}{R1+R2})-0.24522\)
\(Vin(1.09896)(\frac{R2}{R1+R2})=Vin(\frac{2.5}{4.59-0.41})\)
\(\frac{R2}{R1+R2}=0.54423\)
\(R2=1.1941(R1)\)
The last step is to use an online resistor ratio calculator such as this one to choose the best values of R1 and R2, and R3 and R4.
