opamp always saturate, help
MikeML
5,444
I see no saturation. U1 swings from +1.5V to -1.5V.
U2 is sitting at 0V
The emitter follower is following... (It wouldn't if it had a load because it is not biased right).
Santa klaus
Joined Nov 16, 2014
36
Could you check the output current. it should be sine wave (maybe with crossover distortion), i currently get a square signal.
Also, can i leave the follower biased this way?
MikeML
5,444
Could you check the output current. it should be sinusoidal (maybe with crossover distortion), i currently get a square signal.
Are you asking about the audio.asc file you posted, or something else?
34,468
Your audio.asc circuit has only a passing resemblance to the circuit you referenced.
Why don't you simulate the referenced circuit?
34,468
U2 has no input resistor so it is acting as a comparator. Add a 2kΩ resistor in series with the output of U1.
If you look at the referenced circuit, it uses a pot for R2 which provides the resistance you are missing.
Santa klaus
Joined Nov 16, 2014
36
Awesome, it solves the problem . I have an amplified sine wave but there some little deformation around 0
, it
