OP versus TS
Discussion in 'Off-Topic' started by djsfantasi, Jan 31, 2015.
  1. djsfantasi
    Thread Starter AAC Fanatic!
    Apr 11, 2010
    2,911
    881
    From another thread:
    It took me a while to get used to TS. Due to a couple of acquaintances from the office, something else comes to mind when I see TS. Posters here will always be an OP first...
  2. ScottWang
    Aug 23, 2012
    4,933
    777
    When I saw the OP at the first time on this forum, the op amp was come up in my mind, but I think maybe it isn't, then I get used to it, the new system change to TS, but I saw many members still using the OP, although I prefer the OP than TS, but I still follow the new name -- TS, so I think the members will using OP to point to the Original Poster and using op to point to the op amp.
  3. #12
    Nov 30, 2010
    16,705
    7,355
    Tendency to not change until forced to = inertia
    People have it.
    Many will slowly change to T.S.
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    I will have to "ease" into it to avoid PTSD.
    Sinus23 and #12 like this.
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    oh dears
    i'll get blamed for everything now
  6. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    I blame "text speak"! Why not just say thread starter or original poster to avoid confusion?
  7. WBahn
    Mar 31, 2012
    18,089
    4,917
    I'm curious as to how the change came about in the first place. Is there some document put out by XenForo that states that the person that started a thread is to be referred to as the "thread starter", abbreviated TS?
    How was this change promulgated?
    I do see a motivation to disambiguate Original Poster from Original Post, but the context almost always suffices for that just fine.
    I'm sure I'll come around in time. If I were involved on a bunch of boards that used a mix of the two, it would be harder.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    I think part of the decision has to do with thread ownership. When a TS writes in their own thread it is obvious, even if you start in the middle (which I occasionally do). I'll probably stick with OP until I get my fingers burned.
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    On many other forums I see the TS appear.
    TS can be Topic Starter or as called here Thread Starter.
    The name here comes from the plugin for the forum software that jrap installed.
    This was done on request of a member, see this thread for more info:
    http://forum.allaboutcircuits.com/threads/which-one-is-op.100061/
    Bertus
  10. atferrari
    Jan 6, 2004
    2,670
    785
    I recall when Microcip changed the name of the files you needed to deal with in a certain project to "nodes". :( When I started to keep that new and ridiculous name in mind, it disapeared in a major revision of MPLAB. :confused:
    Hey DJ, I can live and I feel fine with both and survive. :)
