Hi Everyone,
I would like to inquire or clarify about the characteritic of the OP-AMP,
which currently Im making High Current Side Sense Circuit at the
secondary side of my current power supply design, and Im planning
to use an OP AMP as Non-inverting amplifier sensing the voltage across
the sense resistor and amplify it.... And my inquiry is that the Common
Mode Input Range must be always less than the VCC of the OP AMPS?
If yes, what is the explanation? IS there any available OP AMPS that
could accomodate higher range of Common Mode Input Range greater
than its' VCC?
than its' VCC?
