op-amp
Discussion in 'Homework Help' started by uofmx12, Mar 8, 2011.
  1. uofmx12
    Mar 8, 2011
    55
    if I have a ideal op-amp of an instrumentation amplifier with 2R1, R2, R3, and R4. with v1=Vcm-Vd/2 and v2=Vcm+Vd/2.
    Finding Ad and Acm:
    Ad=.5[(R4/(R2+R3) ) (R4/R1 + 1) + (R4 / R1) ]
    Acm=(R4/ (R2+R3) ) (R4/R1 + 1) ( R4/R1)
    Would those equations be correct?
    or Acm=0?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would help us better understand your equations if you would post a diagram of your circuit.
    hgmjr
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Agreed. I am baffled by posts like these. What are they thinking?
  4. uofmx12
    Mar 8, 2011
    55
    I figured everyone knew what an ideal op-amp instrumentation amplifier looked like. Let me google it for you:
    http://www.electronics-tutorials.ws/opamp/opamp21.gif
    With R1=2R1.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Link does not work. How about a schematic with all those resistors placed and labeled?
  6. uofmx12
    Mar 8, 2011
    55
    what about now? I used the insert link button.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Before you post, click on the Go Advanced button, post your link, then click on the Preview button and test your link before you click on Submit Reply.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I know what the circuit looks like, but I haven't memorized the resistor reference designators. In fact, I doubt that they are standard.
  9. uofmx12
    Mar 8, 2011
    55
    my link works when I click on it in my post. So not sure what the problem is.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    When I click on your link, I get a blank page with this text in the upper left corner:
  11. Ron H
    Apr 14, 2005
    7,050
    657
    OK, I got the schematic.
    In your original post, what does 2R1 mean?
    You can find the gain equation on the Internet.
  12. uofmx12
    Mar 8, 2011
    55
    Ok, so if 2R1=4k, R2=100k, R3=10k, and R4=10k, Find differential gain and common mode gain, would I use those equations in first post? Assumming V1 and V2 what I put.
  13. Ron H
    Apr 14, 2005
    7,050
    657
    I still don't get the 2R1 thing. Why didn't you just say R1=2k?
  14. uofmx12
    Mar 8, 2011
    55
    that is the case, by my circuit has 2R1 instead of R1. SO R1=2k
  15. Ron H
    Apr 14, 2005
    7,050
    657
    Have you searched for the gain equation?
  16. uofmx12
    Mar 8, 2011
    55
    No, Acutally I believe Ad=R4/R3(1+R3/R2). I have a problem in my book that states.
    For instrumentation amplifier a designer proposes R2=R3=R4=100k, 2R1=10k. For ideal components, what is difference mode gain, common mode gain.
    The solution uses Ad above to get 21V/V and Acm=0. So, not sure what Acm equation is but doesn't look like my equations on original post are correct.
  17. Ron H
    Apr 14, 2005
    7,050
    657
    That equation doesn't even contain R1, so it can't be correct.
    The correct equation is all over the internet.
  18. uofmx12
    Mar 8, 2011
    55
    Ad=R4/R3(1+R2/R1), wrote the equation wrong
  19. Ron H
    Apr 14, 2005
    7,050
    657
    Ad=R4/R3(1+2R2/R1)
  20. uofmx12
    Mar 8, 2011
    55
    how is it 2R2? Confused now, as the solution that was provided for the problem I mentioned in previous post, we used the Ad I posted. With Acm=0, so would Acm=0 here?
