op amp
Discussion in 'Homework Help' started by prejval2006, Dec 4, 2006.
  1. prejval2006
    Oct 25, 2006
    21
    why an operational amplifier is called differential amplifier not a difference amplifier
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    A differential amplifier is a configuration of op amp that amplifies a difference between two input voltages. It is a little vague but my understanding is that a differential amplifier is the general configuration, reference All About Circuits - Volume 3:Chapter 8, whereas a difference amplifier is a special case where each resistor in the feedback network of the differential amplifier is equal, thus giving an output that is a pure representation of the difference between the inputs, i.e. Vout = V2 - V1
    It is common practice to use the name differential and difference interchangeably when referring to op amps.
    Dave
