op amp
Discussion in 'The Projects Forum' started by sasek, May 11, 2010.
  1. sasek
    Jan 3, 2010
    64
    hai all,
    currently im using LM324 to make simple amplifier and i have 12V to put at Vcc+. Now i have problem to supply Vcc- because i did not have negative voltage source. Here i need some help how could i supply Vcc- with only 12V source????
  2. retched
    Dec 5, 2009
    5,201
    313
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    The LM324 is supposed to be able to operate off a single power supply 3-32V range. The input common mode includes ground.
    If you actually require a split supply (centre-grounded) you can employ a resistive voltage divider - with equal resistors to create a virtual ground at the centre point. Some capacitive bypassing to both + & - rails might be beneficial.
    You can be a bit more "tricky" and use one of four the on-board amps with the equal R voltage divider as a unity gain (buffer) ground driver.
