op AMP
Discussion in 'General Electronics Chat' started by ramphisaj, Oct 20, 2006.
  1. ramphisaj
    Oct 18, 2006
    7
    hey everyone. can somebody give me a general way of solving op amp related circuits. i seem to be battling when ever i come across an op amp. thank you
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    If you have a particular opamp circuit that is giving you difficulty you can post it here to see what suggestions you get on how to solve it.
    hgmjr
  4. ramphisaj
    Oct 18, 2006
    7
    this is the example for the op amp that hgmjr requested
  5. JoeJester
    Apr 26, 2005
    3,393
    1,211
    have you done any work on your problem??
  6. pebe
    Oct 11, 2004
    628
    The bottom LH amp has –0.1V on its non-inv input and +0.18V on its inverting i/p, so its output will be at, or near, its –ve supply rail.
    There is not enough information about the OP amp types and supply rail voltages to give an answer to your problem.
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    The first opamp stage in the bottom leg of the circuit appears to be missing information on the value of the voltage source that is applied to the 10K resistor connected to the negative input.
    hgmjr
  8. pebe
    Oct 11, 2004
    628
    I had assumed that the square symbol at the end of the 10K was connected to the same square sybol labelled '2V' at the RH side. That may have been a wrong assumption.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    pebe,
    I think your assumption is certainly a reasonable one based on the symbol used.
    My hope is that ramphisaj will help us out by confirming your conclusion.
    hgmjr
