Op-amp
Discussion in 'General Electronics Chat' started by atlas, Jul 29, 2006.
  1. atlas
    Jul 18, 2006
    28
    Hi guys,
    I'm just wondering if there's an op-amp that can amplify few micro volts to volts...As I need to design an op-amp integrator that can amplify few micro volts to volts... Please if there's just tell me the model name.. Thanks a lot ...
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Could you quantify your requirement a bit better? How many microvolts, and how many volts? It will be easier if you use multiple devices, rather than one, considering the amount of amplification.
    I believe you might want to do your amplification, and then integrate the result. Do you have a circuit you can post for commentary?
  3. atlas
    Jul 18, 2006
    28
    I need to desgin an integrator where the in the put to this integrator will be in terms of micro volts.. For example, 60 micro volts of input and the integrated result would be 6 volts.This means the input will always be in terms of microvolts and the integrator should be able to amplify it to volts .Just like when ideal integrator works.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Integration is the product of the amount of change in an input over time. See http://www.allaboutcircuits.com/vol_3/chpt_8/11.html for more on this. DC signals integrate to zero.
    Your function is amplification - making a 60 microvolt input into a 6 volt output. I would go for a gain of 100,000 in two steps - 100 and 1000. An OPA2134 dual op amp might do very well.
  5. atlas
    Jul 18, 2006
    28
    Yeah what you said is correct, but my input keeps changing, it's not constant coz if it's constant then my op-amp will go into sautration. My input is in terms of micro volts and keeps changing.. I would like to go for a gain of 100,000 but do u think there's a way to do that in one step rather two steps??
    Thanks a lot for your reply....
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You can always try to get there in one step. Look for an op amp with extremely low offset current, as that will cause output errors.
    With proper feedback, a static input should not cause your op amp to sautrate. perhaps you could post a circuit to help the discussion?
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  8. nanobyte
    May 26, 2004
    118
  9. atlas
    Jul 18, 2006
    28
    Thanks a lot guys. I found an excellent op-amp with very low offset voltage (op297)..
    I'm wondering if there's Controlled Current Source IC compnent in the market.. If you know please let me know.....
  10. atlas
    Jul 18, 2006
    28
    Is there an op-amp with offset voltage of nanovolts?? As I tried to look for this type but what I found was in terms of microvolts.. Thanks a lot
  11. pebe
    Oct 11, 2004
    628
    Have you looked at chopper stabilised op-amps?
  12. atlas
    Jul 18, 2006
    28
    yeah I found it.. Thanks a lot ...
  13. atlas
    Jul 18, 2006
    28
    I'm looking for a current controlled source, but I cannt really find any.. Does anyone know about it??
