Op Amp Zero off set
Discussion in 'The Projects Forum' started by BobW55, Mar 14, 2015.
  1. BobW55
    Thread Starter Active Member
    Jul 22, 2008
    43
    I am working with an unknown 8 pin op amp that is rated for a min of 5 volts.
    I am only using 3 volts. Would this cause me to NOT be able to adjust it to zero?
    It has a UV sensor hooked to it, and in total darkness I still get over 700 mv output, even with the zero adjust pot maxed out.
    Bob
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Using opamps outside the specifications can lead to unwanted effects.
    Take a suitable opamp.
    Have a look at page B-2 of the following PDF for more info:
    slod006b Op Amps For Everyone.pdf
    Bertus
  3. BobW55
    Jul 22, 2008
    43
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    That is a nasty practice.
    They probably want to protect their schematic, so it can not be reproduced.
    Bertus
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    With Vcc below the minimum operational level you don't really have an opamp. You have something, but parts of the internal workings are probably non-functional. Trying to get zero volts out of a single supply opamp can be challenging under the best of circumstances unless you have a part the operates to the negative power supply rail. The best way to guarantee this is to use a bipolar supply or create a vitual ground at Vcc/2. Then you can define "0" output as mid scale and play away to your hearts content.
  6. BobW55
    Jul 22, 2008
    43
  7. Dodgydave
    Jun 22, 2012
    5,171
    778
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Dodgydave, are you sure it is CA3240?
    ca3240-a.pdf
    Bob says it is likely an 3140:
    CA3140.pdf
    The 3140 has some schematics in the datasheet for offset compensation:
    Bertus
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Can be used in single supply mode with diode to limit output swing. No indication it can go below 5 V though.
  10. Dodgydave
    Jun 22, 2012
    5,171
    778
    ca3140 has dc off set
  11. BobW55
    Jul 22, 2008
    43
    The board you see in the picture I posted is what I have. I have no schematic of the unit. Only data sheet I can find is in Chinese.
    http://us.100y.com.tw/pdf_file/57-A24B-UVM-30A.pdf Took me forever to translate which trim pot was which.
    Tried changing the zero offset pot from 1K to 10K dropped the output a few MV.
    Being that I do not have a schematic, nor can I see the traces on the board to reverse engineer it, I am kind of stuck.
    Will have to try and add some resistors to either side of the Zero adjust pot and see what that does for me.
    While I understand the basics of an Op Amp, my expertise is VERY limited. I also intend to hook this up to a 5 volt supply and see if that is what is making it
    not read a zero output.
    May have to abandon what I have and build my own from scratch.
    Thanks everyone for all the input.
    Bob
  12. Dodgydave
    Jun 22, 2012
    5,171
    778
    dc off set is pins 1-5, with th wiper to pin 4, what happens when you short pins 2 and 3 together, does the output on pin 6 go to zero..
  13. BobW55
    Jul 22, 2008
    43
    Dave,
    Will give that a try tomorrow.
    May have to rebuild the amplifier from scratch and keep the sensor part.
  14. BobW55
    Jul 22, 2008
    43
    Here are some test results.
    Running from a 6 volt supply
    Shorting pins 2-3 drops to 1.5mv, may not have had the best contact on the pins, hard to do with surface mounted stuff,
    Lowest I can drop the in the dark voltage to is 38.9mv on the out put of the board.
    Got the same results using a 3 volt power supply.
    Right now there is a 10K multi turn pot on the zero adjust. Have 2 thoughts,
    1) Try a 1 meg trim pot.
    2) build my own amplifier for this thing and just use the sensor from the existing one.
    Only thing I can add is that the amplifier is amplifying voltage, not current to voltage. The sensor part has a small current to voltage amp of some sort on it already.
    Course I could spend the $300 that Davis wants for their uv sensor but what fun is that.
    Bob
  15. crutschow
    Mar 14, 2008
    13,523
    3,392
    Do you know what the sensor dark current is?
  16. Dodgydave
    Jun 22, 2012
    5,171
    778
    Try a 1nF cap across pins 2,3
  17. BobW55
    Jul 22, 2008
    43
