Op Amp with slew rate of 10,000 V/micro second exist?
Discussion in 'General Electronics Chat' started by ping222, Feb 5, 2014.
  1. ping222
    Nov 7, 2013
    13
    I would like to amplify a 2 GHz sinusoidal voltage signal (0.22 V peak to peak) using an operational amplifier. The gain I would like from the operational amplifier is about 5, that is, I would like a voltage output from the amplifier to be approximately 1 V peak to peak given the input. The problem is I can't seem to find an op. amp. with a slew rate that can give me the desired performance. The slew rate I require can be calculated for a sinusoid to be 2*pi*f*Vpp where,
    f is the frequency of the signal (2 GHz in my case)
    Vpp is the peak to peak output voltage required (1 V in my case).
    Using this formula I require a slew rate of 12,566 V/micro second. I can't seem to find anything out there that exists that can go this fast. I don't have much experience with op. amps. Do they currently exist to meet my specifications? Thanks in advance for any feedback,
    Regards,
    Ping.
  2. atferrari
    Jan 6, 2004
    2,663
    784
    Most probably not that fast but there were some that National used to call in their books "dam fast" op amps.
    ping222 likes this.
  3. LvW
    Jun 13, 2013
    674
    100
    Ping22, try to find a suitable amplifier in current-feedback topology (CFA).
    I know they exhibit slew rates of several thousands of volts/µs.
    Such amplifiers can be used and wired like conventional opamps.
    The only point to be considered is that the feedback resistor must be larger than a specified minimum.
    ping222 likes this.
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    does it need to be an op amp? if not, there are sevral MMIC's that will amplify with more gain than tha at 2 ghz. check out MINICIRCUITS LABS site for info.
    ping222 likes this.
  5. #12
    Nov 30, 2010
    16,673
    7,320
    Basic rule: The more parts in a stage, the slower they are, even if for no other reason than parasitic capacitance and inductance. One or two transistors stands a better chance of going fast than 50 or 100 transistor on an integrated chip.
    ping222 likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    ping222 likes this.
  7. RichardO
    May 4, 2013
    1,336
    429
    I think that you are off by a factor of 2. Slew rate is 2*pi*Vpeak.
    Even at "only" 6,000 v/us you are in a lofty realm. You should consider a video amp or ADC driver instead of a true op-amp. Maybe one like this:
    http://www.linear.com/product/LTC6417
    ping222 likes this.
  8. ping222
    Nov 7, 2013
    13
    Thanks guys for all of that, I will look into it and post what I find. With regards to 'RichardO' post, yeah I am pretty sure it is sinusoid peak to peak voltage that is required in the 2*pi*f*Vpp calculation. Therefore would not be off by a factor of two in that case.
  9. #12
    Nov 30, 2010
    16,673
    7,320
    Typo. It's 2 Pi F Vp
    not Vp-p
  10. crutschow
    Mar 14, 2008
    13,488
    3,372
    I have to weigh in. It's 2*pi*f*Vp as shown here. It's calculated as the peak value of the derivative of the sinewave or d/dt (Vp*sin(2\omegat)) = 2*pi*f*Vp * cos(0) = 2*pi*f*Vp.
