Op amp with low output impedance
Discussion in 'General Electronics Chat' started by TimaV, Sep 22, 2014.
  1. TimaV
    Sep 15, 2014
    How to use a transformer to make from a specific resistance to 50 ohm?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    what does a transformer have to do with opamp?
  3. MrCarlos
    Jan 2, 2010
    400
    134
    Hello TimaV
    You're looking for an OpAmp with an output impedance of 50 Ohms ??. . . Or Its input ??
    Or want to know how to use a transformer which has an impedance of 50 Ohms ?
  4. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Sorry we cannot understand that. Please restate your problem. Do use lots of words. Do not use abbreviations or undefined acronyms.
  5. wmodavis
    Oct 23, 2010
    737
    150
    Draw pictures if possible. Clear communication is imperative if you want helpful, accurate, useful answers.
  6. Ramussons
    May 3, 2013
    562
    92
    The transformation of impedence is "square of the turns ratio". If a transformer has a 1:2 turns ratio, the impedence "x" on the "1" side will be seen as "4x" on the "2" side.
  7. MrChips
    Oct 2, 2009
    12,624
    3,451
    There are opamps such as LM6181 designed to drive 50-ohm loads.
