Op Amp - What is the purpose of the 1 ohm resistor and cap to ground
Discussion in 'General Electronics Chat' started by KB3X, May 7, 2016.
  1. KB3X
    Dec 17, 2015
    In this sample non-inverting op amp circuit from Texas Intruments from the LM675 datasheet..
    http://www.ti.com/lit/ds/symlink/lm675.pdf
    What is the purpose of having the 1 ohm resistor and 0.22uF capacitor in parallel to the load?
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    That's very similar to an op-amp, but its actually an AF power amp.
    The CR network is often called a Zoebell network - its sometimes called by another name that I can't remember right now.
    AFAICR: it damps spurious oscillation on the output stage.
  3. crutschow
    Mar 14, 2008
    13,482
    3,370
    It is being used as a audio amp to drive a speaker, and the resistor and capacitor roll off the high frequency response above the audio range to stabilize the amp, avoiding oscillations due to the reactive speaker load.
  4. AnalogKid
    Aug 1, 2013
    4,687
    1,297
    The schematic symbol for many audio speaker amplifiers look like normal opamps. They are not. Audio speaker amplifiers are weird, squirrely, and tempermental. They require careful decoupling plus things like the zobell network to prevent breaking into oscillation. Just a warning...
    ak
    OBW0549 likes this.
  5. OBW0549
    Mar 2, 2015
    1,390
    932
    I've always referred to these as "snubber" networks; I think that may be the most common term.
  6. crutschow
    Mar 14, 2008
    13,482
    3,370
    The spec sheet lists it as a power op amp, so I think it's a more general purpose amp then those labeled as audio power amps.
  7. ian field
    Oct 27, 2012
    4,447
    791
    There's a sort of grey area between power op-amps and audio power amplifiers, some are equally at home in either application - some are a little more fussy.
    Sometimes ultra fast buffers look the same as a schematic symbol, but they're not the best choice for audio amplifiers.
    Made for the job audio amplifiers usually have a bootstrap pin so a capacitor can couple the output back to the base bias chain. This increases the gain and linearity of the emitter follower pair.
    These days most people go for at least a BTL amplifier, unless they need a common terminal for a headphone jack.
    Class-D is rapidly gaining ground - you can get a few watts from a DIL or SOIC package with no heatsink whatsoever.
    GopherT likes this.
  8. KeepItSimpleStupid
    Mar 4, 2014
    1,265
    222
    That network can also be designed as a sort of inductor. A carbon resistor with a winding over it in series with a capacitor.
  9. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Page 7 of the datasheet has some notes about stability.
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    The Boucherot cell is answer. but a more common name is zobel network.
