Hi I'm supposed to find Vo I the attached image.
I just want to confirm one thing. I labelled a node a V3 I know in an op amp the voltages of both leads going in to an op amp are the same.
The second branch has just a wire from ground to the op amp. I know the current of that is 0. Since the current is?0 can I say V3 is 0?
The original question asks to find v0 in terms of everything labelled (not v3)
