op amp Transfer
Discussion in 'Homework Help' started by jstrike21, Feb 18, 2010.
  1. jstrike21
    Sep 24, 2009
    104
    [​IMG][​IMG][​IMG]
    Im struggling on starting to get the transfer function here any ideas on how to start?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. mik3
    Feb 4, 2008
    4,846
    63
    Assume that the input current to the op amp is zero and that the inverting node (V-) and non-inverting node (V+) voltages are equal. Find (V-) from Vo by using the voltage divider rule. Then say that (V+)=(V-). Find (V+) with respect to Vin and then equate (V-) and (V+). Finally, rearrange as to find Vo/Vin.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Also, R3 is irrelevant. It will not appear in the transfer function (assuming an ideal op amp).
