Op Amp transfer function
Discussion in 'General Electronics Chat' started by RFeng, Jul 5, 2012.
  1. RFeng
    May 30, 2012
    27
    I'm trying to figure out the transfer function of the following Op Amp Intergrator:
    Can you please advice on that?
    Thank you!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It is a integrator. Not sure what the biasing network on the + input is about, it could be replaced with either power supply or a resistor network and a single power supply.
  3. WBahn
    Mar 31, 2012
    18,093
    4,920
    Replace the feedback network with a single impedance that is the parallel combination of the R and C. Then analyze it like any other opamp circuit, noting that the voltage on the inverting input is not at virtual ground, but rather at Vplus.
  4. RFeng
    May 30, 2012
    27
    Hi guys.
    Thanks!
    I analyzed it and reach its transfer function:
    * R1 - Resistor at (-) Input
    * Zf - Impedance of Feedback
    How can you tell what is the pole of this transfer function?
    Thanks again!
  5. RFeng
    May 30, 2012
    27
    Back to page 1 if I may :)
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Z_f=\frac{R_ f\frac{ 1}{ C_f s}}  {R_f+\frac{ 1}{C_f s } }
    etc.
    No negative sign.
  7. AdrianN
    Apr 27, 2009
    97
    Well, I do not see R1 in your schematic so the transfer function must be:
    Vo = -Zf/R2 * Vi + V(+)*(1+Zf/R2)
    Since V(+) is DC, it has no dynamic influence. It just moves the output DC level up or down depending on the combination of VSET and Vdc DC voltage level. The signal rides on top of this DC level. So, the transfer function can be rewritten as:
    Vo = -Zf/R2 * Vi + V(+)*(1+Rf/R2)
    The signal amplitude is given by
    Vo_signal = -Zf/R2 * Vi, and can be written as
    Vo_signal = -1/(1+ s Cf Rf)* Rf/R2 * Vi
    So the pole is at
    1/(2 pi Cf Rf) = 159.15 kHz. It is only determined by Cf Rf time constant. Since both resistors Rf and R2 are 1kohm, the signal amplitude is identical with the input amplitude (inverted), but rides on top of the DC level we discussed. The unity gain starts dropping after 159.15kHz.
