Hi Guys
Its been a while since I've been able to get my teeth into an electronics project, and I've been loving life the past week until I hit a brick wall trying to get a sensible op amp output into the adc of a PIC18F, and I was hoping somebody would be good enough to put me on the right track
As I couldn't find anything suitable on the market, I've built a thermostat system which monitors and heats both parts of a 40kg Aluminium cast using a 150w silicon heat pad adhered to each part.
Each pad is powered by a 30v; 5A bench supply, channelled through a 10A relay which is switched by a L293D, controlled by the PIC. The PIC is controlled by a windows form C++ app through USB connectivity.
To monitor the temp of the Casts in real time, I'm using a K-type thermostat for each part, who's output is fed into a LF347N op amp, but I'm having difficulty reading any sensible data on the PIC pins.
I've tested the software by feeding the output of a voltage divider into each of the adc inputs, and I also get a linear voltage output of the op amp when I heat the thermocouple in a pan of water. I'm guessing I have some issue with signal conditioning but I think this may be beyond my ken...
I'd really appreciate a nudge in the right direction.
Martyn
Martyn
