op-amp supply question...
Discussion in 'General Electronics Chat' started by WAN24, Jan 9, 2008.
  1. WAN24
    Jun 27, 2006
    21
    this is a simple question, but im not sure...can two op-amps share a single supply? :confused:
    tnx..
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Yes. The number of op-amps which can share a single supply is only limited by the current the supply can source.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, it's done all the time.
  4. WAN24
    Jun 27, 2006
    21
    tnx for the reply sir..
    if im gonna use 3 to 4 op-amps.. what current rating of the transformer should i use? coz im trying to make a power supply for those op-amps... again. tnx..
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The op amp spec sheet will tell you the current each can be expected to use. If your supply can source 100 milliamps on both supply rails, then it should be adequate. It's always a good idea to check the requirement of the op amps, though.
  6. WAN24
    Jun 27, 2006
    21
    ok... tnx sir!!! now i know...
  7. Distort10n
    Dec 25, 2006
    429
    The next question would be, do you bypass ALL pins? :cool:
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What knightofsolamnus is referring to is the practice of connecting small capacitors (usually 0.1uF) from the op amps' supply pins to the ground pins. If you are using single-supply (only V+ and ground) op amps, connect a single 0.1uF capacitor from the V+ pin to the ground pin.
    You will need more than just a transformer; you will need a regulated power supply. If you don't have one, you could build one from a left-over computer power supply.
