Op Amp Substitute
Discussion in 'The Projects Forum' started by dickcruz, Jan 9, 2007.
  1. dickcruz
    Jan 7, 2007
    20
    I need a substitute for the LMH6642 opamp
  2. dickcruz
    Jan 7, 2007
    20
    the substitute should be compatible with this circuit
  3. Distort10n
    Dec 25, 2006
    429
    What is wrong with the LMH6642? Asking for a substitute for a circuit is too broad of a question. What is the application of the circuit in your design.
    Voltage Feedback?
    Current Feedback?
    High Slew Rate?
    Low input bias?
    What are your critical parameters?
  4. dickcruz
    Jan 7, 2007
    20
    voltage feedback.
    I am unable to get the part where i live.
    I need something with the same charecteristcs
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is your application? If we knew something about that, we might be able to suggest alternatives.
  6. Distort10n
    Dec 25, 2006
    429
    There are plenty of manufacturers that have parametric searches. Since this is a photodiode application look for the following:
    High input impedance
    Low input bias current
    These two parameters go hand and hand. Low input bias current in the range of pA screams FET input. OPA129 has input bias currents on the order of fA.
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Would an ADA4851 work?
