Op amp spec for tunable filter
atferrari
Joined Jan 6, 2004
4,770
I've run across a design of a tunable state variable filter using AD825 op amps.
My idea is to replicate the design for a maximum f0 of around 130 KHz.
What could be a correct (and not costly) replacement of those op amps?
I was thinking to use dual / quad ones but I do not know what actual specs to look for. Sure slew rate, low noise. Something else?
As per what I read GBW product has to be 10, 50 or 100 times the highest f0? How much should it actually be?
