op-amp schematic analysis
Discussion in 'General Electronics Chat' started by eng_alaakaa, Sep 28, 2011.
  1. eng_alaakaa
    Sep 21, 2011
    12
    Hi all,
    my graduation project about RFID , and this schematic is concern reader, my problem is the function of every op-amp that concern the receiver part of the reader.......... the picture is attached with my post.
    and thank you all:).
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    1 - Voltage follower
    2 - Inverting amplifier
    3 - High pass active filter
    4 - Inverting amplifier
    5 - Comparator with hysteresis
    eng_alaakaa likes this.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  4. colinb
    Jun 15, 2011
    351
    35
    The Microchip schematic shows the LM339MA op-amp with inputs floating. Is that a Bad Thing? I remember reading that unused op-amps should be not have their inputs left unconnected (e.g., configure as voltage follower).
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    LM339's are comparators that have open collector outputs.
    The unused inputs should be grounded. The unused outputs can be left disconnected.
  6. colinb
    Jun 15, 2011
    351
    35
    Has anyone else thought that op-amps and comparators should have different schematic symbols?
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, they actually have a lot of similarities - it's just that they are optimized for their particular functions.
    In a limited way, you can use one for the other - at low speeds, and if you don't really care about optimal response.
    You'll quite frequently see schematics where someone used 3 of a quad opamp as opamps, and the remaining one as a comparator - or something similar.
    A new member posted a schematic of a PWM circuit, and wanted an explanation of how it worked. It used two channels from an LM324; one as an opamp to create a triangle wave, and the other as a comparator. They could have just as well used an LM393 dual comparator. National actually markets an IC that has an opamp for one channel, and a comparator for the other; that would be a good device to use for such circuits.
    The LM392 opamp/comparator:
    http://www.national.com/ds/LM/LM392.pdf
    The opamp is like a channel from an LM158/LM358.
    The comparator is like a channel from an LM193/LM393.
