op amp recommandation for commonly used modern op amp
Discussion in 'General Electronics Chat' started by kevin.cheung19, Nov 28, 2011.
  1. kevin.cheung19
    Nov 22, 2011
    24
    I have been using 741 op amp for quite some time now, and occasionally uses TL081 because they are generally purpose op amp. My question is, I know there are a whole lot more of modern op amps out there, from what i've read LM6132, LMC6482 are some good ones. Would anymore mind to share what are some common modern op amps out there you used and for what application are you using it for and which of the spec were the deciding factor in using that op-amp? This would really help me in learning about more in-dept detail of op amp. (I know how to use op-amp, so please kindly no lecture of how to use op-amp:p)
    If some one can get a list going, I'd much appreciate it.
  2. lowprofile
    Member
    Oct 31, 2011
    33
    kevin.cheung19 likes this.
