op amp rail voltages
Discussion in 'General Electronics Chat' started by jrevard, Jan 6, 2014.
  1. jrevard
    Jan 6, 2014
    hi, how can I create the rail voltages for an op amp? the (+) voltage seems simple enough but I'm not sure how to supply the (-) voltage... I am seeing that for working with a DC signal the (-) terminal can be connected to ground but what about for AC signals?
    thx
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Depends on AC signal.
    If AC is centered on zero, then your AC signal is from -X to +X volts. So you need to provide a negative rail.
    If AC is centered on some positive value and the range of AC is, for example, from +1 to +5, then you don't need negative rail, just connect it to ground.
  3. #12
    Nov 30, 2010
    16,665
    7,310
    Build a power supply to create a negative voltage and connect that to the (-) supply terminal of the op-amp.
  4. tubeguy
    Nov 3, 2012
    1,157
    197
    +1
    Using only a positive supply, if your AC signal is centered around 0 volts you can also deal with that by biasing the op amp's input at 1/2 the supply voltage using 2 resistors and coupling the input signal thru a capacitor.
  5. shteii01
    Feb 19, 2010
    3,500
    511
    If you don't need anything outrageous, you can use computer power supply, they usually have a couple negative voltages.
  6. #12
    Nov 30, 2010
    16,665
    7,310
    or a 9 volt battery if you're just experimenting for a while.
  7. Brownout
    Jan 10, 2012
    2,375
    998
    If you have two power supplies, you can connect them in series and use the wire between the two as 0V, or ground. They you'll have rails for + and -.
  8. shteii01
    Feb 19, 2010
    3,500
    511
    Someone posted a pic of such setup a couple of months? ago. I tried to find it, but no luck.
  9. shteii01
    Feb 19, 2010
    3,500
    511
    It was posted on these forums, but I found it with Google.
    Connect -9 volts from the battery to the negative rail of the op amp. Connect +9 volts from the battery to the positive rail of the op amp. Connect the ground from the batteries to the circuit ground.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    The claim that you can connect the negative rail to ground if you are working with DC signals isn't a valid statement. As with AC signals, if the input and output signals are compatible with grounding the negative rail, then you can ground the negative rail. If they aren't compatible with a grounded negative rail, then you can't.
  11. jrevard
    Jan 6, 2014
    Awesome, you guys are great
  12. w2aew
    Member
    Jan 3, 2012
    219
    64
