op-amp quiescent current
Discussion in 'The Projects Forum' started by Blackbull, Aug 29, 2008.
  1. Blackbull
    Jul 26, 2008
    70
    6
    Could anyone tell me if an op-amp draws current when there is no input or output? Do the batteries need to be disconected when not in use? Many thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, they do - the quiescent current for each device is on its data sheet. Disconnecting the battery is the only way to achieve zero current draw.
  3. Blackbull
    Jul 26, 2008
    70
    6
    Thanks beenthere, I did look at the data sheet but couldn't find it. What a brill site this is.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    In the TL072 datasheet, it is called Icc.
  5. Blackbull
    Jul 26, 2008
    70
    6
    Very good Ron, that's 2% of the data sheet I can understand!!!
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet tells you what is Icc:
    Supply Current (each amplifier) 1.4mA typical and 2.5mA max.
    If the opamp is doing any work then add the working current.
