OP-AMP question?
Discussion in 'Homework Help' started by error404, Apr 25, 2010.
  1. error404
    Apr 25, 2010
    5
    [​IMG][​IMG]
    How can i find Vo voltage and Io current? This question is very complicated for me. Please help me.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The op amp will likely go to full voltage on either power supply rail, so it depends on the component being used. Very few op amps anywhere near the power supply rails.
    You don't have a component for the op amp, you don't have power supply definitions.
    In short, as stated the question is unanswerable.
  3. retched
    Dec 5, 2009
    5,201
    313
    Being a homework question, it is either ideal or a 341 ;).
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Show us how you think the solution to the problem should be set up.
    hgmjr
  5. mik3
    Feb 4, 2008
    4,846
    63
    Find V- (inverting input voltage with respect to ground) and V+ (non inverting input voltage with respect to ground).
    Then equate V- and V+ (ideal op amp) and you should find Vo with respect to Vin.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Using the hint Mik3, see if you can take a stab at solving the problem and post it here.
    hgmjr
  7. mik3
    Feb 4, 2008
    4,846
    63
    V+=(Vo*12k)/(12k+8k)=0.6*Vo , voltage divider rule
    current through 4k and 16k is: assume current flows from Vo to 6V
    I=(Vo-6)/(4+16)k=(Vo-6)/20k
    thus
    V-=6+I*4k=6+4k(Vo-6)/20k=6+(Vo-6)*0.2=6+0.2*Vo-1.2=0.2*Vo+4.8
    assuming V-=V+
    0.6*Vo=0.2*Vo+4.8
    thus
    0.4*Vo=4.8
    thus
    Vo=12V
    Io=12V/10k=1.2mA
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Millman's Theorem Solution.......
    \small V_-=V_+
    \frac{\frac{6}{4K}+{\frac{V_o}{16K}}}{\frac{1}{4K}+{\frac{1}{16K}}}=\frac{\frac{V_o}{8K}}{\frac{1}{8K}+{\frac{1}{12K}}}
    \frac{6(16K)+4K(V_o)}{16K+4K}=\frac{12K(V_o)}{12K+8K}
    \frac{6(16K)+4K(V_o)}{20K}=\frac{12K(V_o)}{20K}
    \normalsize {6(16K)+4K(V_o)}={12K(V_o)}
    \normalsize {8K(V_o)}={6(16K)}
    \large {V_o}={\frac{6(16K)}{8K}}
    \large {V_o}={6(2)}
    \large {V_o}=12V
    V_+=\frac{12K(12)}{12K+8K}
    V_+=\frac{12K(12)}{20K}
    V_+=7.2V
    I_o=\frac{V_o-V_-}{16K}+\frac{V_o-V_+}{8K}+\frac{V_o}{10K}
    I_o=\frac{12-7.2}{16K}+\frac{12-7.2}{8K}+\frac{12}{10K}
    I_o=0.0003+0.0006+0.0012=0.0021A
    hgmjr
  9. mik3
    Feb 4, 2008
    4,846
    63
    Hgmjr,
    You are right about Io. I thought Io is the current through the 10k resistor only.
  10. error404
    Apr 25, 2010
    5
    Thank you for your answers .
