hi
hi ive been getting some help on more general points on this system,over on tech repair , for which im very grateful,
but i thought i,d give them a break, as this is a bit more straightforward and specific.
i have an op amp in circuit , it is reading. 4.1 volts on the inverting input.
4.37 volts on the non inverting input
and .zero volts on the output
thats with + 15.13 volts on the pos power supply pin and 14.3 volts 0n the neg power supply pin.
as its in a tricky place to get to, could someone please be kind enough to confirm that the op amp is faulty.
thank you.
thank you.
