Op-amp project question
Discussion in 'The Projects Forum' started by fender7802, Apr 10, 2012.
  1. fender7802
    Apr 7, 2012
    43
    Hi everyone,
    I'm new to the forum and am pleased to be a member. I have been working on a project where I keep a light bulb at a constant temperature using op-amps. Essentially I take the output of a thermocouple, feed it into an in-amp to get a decent gain, and feed the output of that into a comparator. Depending on polarity of that output either a) light a green LED or b) light a red LED and turn on a fan which points at the bulb to cool it down. Pretty simple idea, I'm just encountering lots of problems when building it.
    The output of my last stage won't power the fan. Before connecting the load I get a saturated output of 10V. Connecting the fan (which has a load resistance of 47k) drops the output voltage to 2V and produces a strange beeping sound from the fan. The fan works fine when tested by connecting to a DC source. Why is the op-amp losing output voltage to such a large load and refusing to power the fan? Thank you very much for any suggestions.
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    What opamp and fan are you using? 47kOhm seems high for a fan.
  3. fender7802
    Apr 7, 2012
    43
    Using a 741 for the output stage. The fan is a 4" 12VDC cooling fan from radioshack.
  4. wayneh
    Sep 9, 2010
    12,376
    3,226
    No way can the 741 power a fan.
  5. MrChips
    Oct 2, 2009
    12,624
    3,451
    You need to determine how much current is required to power the fan.
    It is unlikely that a 741 op-amp can deliver enough current to run the fan.
    You may be able to use a power transistor to drive the fan.
    It would be best for you to post a circuit schematic of your whole circuit.
  6. fender7802
    Apr 7, 2012
    43
    Is there a better choice for a different op amp in this situation?
  7. fender7802
    Apr 7, 2012
    43
    Thank you for looking at the circuit.
  8. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    The 12 inch cooling fan from Radioshack requires 4.2 watts to power from 12 volts, that is 350 mA.
  9. fender7802
    Apr 7, 2012
    43
    Would a power transistor do the trick do you think?
  10. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    A power transistor would work. Just be sure to get one that can support the required current with a bit extra.
  11. GRNDPNDR
    Member
    Mar 1, 2012
    449
    7
    I was under the impression the op-amps current output was dependant on the source powering it. No current flows in or out of the op-amp inputs so any current requirements come from the power supply.
    Am I wrong on that?
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    That is true, but the op-amp can only pass so much current from the supply.
  13. wayneh
    Sep 9, 2010
    12,376
    3,226
    Look for a MOSFET, a special type of transistor. You'll use it like a switch. With 10V or so from the output of your op-amp applied to the "gate", it will be fully on, allowing current to flow from the "drain" to the "source", which is typically connected to ground. When "on", a MOSFET has very low internal resistance and it probably won't even be warm. And there's virtually no current required to drive the gate, so the little op-amp will love it. A normal BJT requires roughly 1/10 of the load current at the base. If that's over 30mA for your fan using >300mA, that would be a lot for that op-amp.
  14. panic mode
    Oct 10, 2011
    1,328
    305
    on the side - why only one of LEDs is connected to current limiting resistor?
  15. fender7802
    Apr 7, 2012
    43
    Since 741's current limit is about 20mA in practice, it seems OK to do that I think.
  16. fender7802
    Apr 7, 2012
    43
    Thank you for that suggestion wayneh. Is there a way to implement that to achieve a certain output current based on the input current? Or is the (Beta) value just fixed? Also: do you think I can get 300mA out of a single MOSFET?
  17. panic mode
    Oct 10, 2011
    1,328
    305
    and much more than 350 mA... pick power mosfet with low on-resistance.
    the reason i mentioned led is that you already have resistor (you could simply connect both LEDs in antiparallel) and if you don't, that LED will clip the output.
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    The first opamp has an input offset voltage that could be as high as plus or minus 6mV which is much more than your signal. 6mV times a gain of 1000 produces an output of 6V.
    You need to add the input offset voltage nulling circuit shown in its datasheet.
  19. wayneh
    Sep 9, 2010
    12,376
    3,226
    Not in the switch (comparator, on/off) configuration, which is what you want, IMHO. Of course you could build a current amplifier. I think what you're asking about is actually a voltage (at the thermistor) to current (at the fan) amplifier. I wouldn't bother unless the thermostat doesn't meet your needs. I bet it will.
    If not, a better way to control the fan proportionally, instead of on/off like a thermostat, would be pulse width modulation (PWM). The PWM approach would use the same on/off MOSFET switch but you would control the duty cycle of a square wave fed to the gate. Much better than trying to control the fan's current.
    Heavens yes, sky's the limit. Just choose a MOSFET with a peak current spec maybe 4X your application.
