Op Amp produces Clicking Noise
Discussion in 'General Electronics Chat' started by Daniel - RoboNoob, Apr 19, 2010.
  1. Daniel - RoboNoob
    May 21, 2009
    11
    Hi all,
    I've attached the output of an audio op amp to a pair of headphones (the input to it is an mp3 player) and I'm hearing a clicking noise in addition to the song. Does anyone know what would cause that?
    Thanks,
    DRN
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    Reduce the volume of the mp3 player and check
  3. Daniel - RoboNoob
    May 21, 2009
    11
    Thanks, but no luck :(
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Headphones are a heavy load for an op amp. The clicks may be the waveform clipping. Op amps are happier with at least several hundred ohms load (the OPA134 will drive 600 ohms), and headphones are more like 32 ohms.
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    next is that are you sure your MP3 songs are clean with clipping signals.
    Try hearing them from speaker and make sure it is clean, if they are then OPAMP supply may be too low or faulty
  6. ELECTRONERD
    May 26, 2009
    1,146
    16
    That doesn't make sense.
    This:
    - Indicates high impedance.
    Contradicts with this:
    - Indicates low impedance.
    Headphones for MP3 players are generally high impedance.
    Austin
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You're right, Beenthere - they are all over the map. Seems like 32 Ohms is popular nowadays. Back in the 70's all headphones were 8 Ohms, except for the piezo ear plugs.
    You really need to use an audio amplifier like a 386.
  9. ELECTRONERD
    May 26, 2009
    1,146
    16
